... I'm not happy as my performance has changed.
Anyone else got this issue?
I will be calling subaru australia tomorrow and emailing fhi for answers. I'm tempted to go back to the old firmware
Hi CROUPT. I agree with
Jayc that the new firmware is far superior to the old. Something doesn’t sound right with your XT though, but as previously mentioned it does take about 3/4 of a tank of fuel for the ECU to relearn, so it may improve. From memory, the ECU reset procedure should have taken care of the throttle position.
However, the following may help.
On 5th August OzFoz.com forum member
RSTI also posted that after the ECU update & 1st service, the XT was lacking performance. The post on OzFoz.com is
here. Logon or registration is required to access this, so if this isn’t possible part of
RSTI’s post read; “After receiving the car back it instantly felt 'flat', like the boost was cut back by half! Acceleration is sluggish and a lot more throttle is required, to obtain less than half the previous acceleration!” & “It's disappointing that a car that was running perfectly, now feels like a NA”.
My reply to this was to ask if they changed the spark plug gap. The correct gap for the XT should be 0.5 – 0.55mm.
The reason I asked about the plug gap was because mine were set too wide by mistake by the Technician at the time of the ECU update, & the first time I used full throttle I got massive pinging at 4500rpm. The second time I used full throttle the engine completely cut-out at 4500rpm then continued a couple of seconds later. The engine also lacked performance & would miss when climbing the slightest hill. Vacuum & idle were also inconsistent to how they should be when first started from cold.
So far
RSTI hasn’t come back to report what was causing the problem.
If the spark plugs were removed for inspection or replacement, I would also check to see if they tightened the clamp closest to the air filter case on the air inlet hose leading to the turbo. The air filter case needs to be removed to access the spark plugs from the top of the engine bay. The tightness of all 8 clamps between the air filter case & the throttlebody on this model XT’s engine are very important. The MAF sensor is in a vulnerable spot just inside the air filter case so be careful not to damage it if removing the air filter element or air outlet hose from the case.
