hard would it be to arrange that? What exactly would need to be done? 2000 forester L
Sounds like a good way to do it. Anyone have the Relay Block Diagram for the 2000 or tell me which relay is the one for the windows?I could tell you how to do it for the SG (2003+) models, but I don't have good diagrams for the SFs. My (educated?) guess, assuming that the models are reasonably similar in this regard, is that if you can find a relay that controls power to the windows when the key is on, you could remove it and insert a short jumper wire into the two terminals that form the leg of its T-shaped footprint in this connector.
On the SG Foresters it would be 17 and 18 on this diagram.
Wouldn't it be easier for them just to push the unlock switch?i think it's also kind of a security flaw...
if windows always work, someone could pry the window open enough such that you can push the window switch...
