My XT has developed an annoying rattle/creaking noise from drivers side front door panel. I had suspected it may have been a result of having trim removed to repair a small dent (paintless dent removal guy). Took it back to dealer. Thankfully they also heard the noise, which is only evident whilst driving on rougher roads. They removed the panel & refitted two plastic plugs. Noise disappeared however has now come back more pronounced and now also in front passenger seat door trim. I could turn up the radio, however I do a lot of country miles and when not on freeways the rattle is starting to get to me! I've clocked up 24,000 km on the XT and love it, however the rattle should not be there.
I've just bought 15 new plugs to refit on drivers door to see if that fixes the problem. If not, back to the dealer. I plan to totally remove the door trim(disconnect all wiring) and drive around to see if rattle is still there and maybe more easy to identify its source.
Will be interested to see if any other 14+ owners have the same problem. Shall keep you posted with the results.
Steve d
Steve d
