21 - 40 of 1,376 Posts
Forester 2.5 XTi,
the file is there and i can download it and view it
i'll add my info as soon as I get my new wheels/tires on
good job and thanks
dm
Discussion starter · #22 ·
Thanks! Glad it works. Whew... Finally!
Discussion starter · #24 ·
That's awesome. Will this be close enough to the Forester tho?
I know we share a lot of Impreza, but I don't know about wheel geometry dynamics in this case.
Discussion starter · #26 ·
Thanks for those!
Tire brand and size: Goodyear Eagle F1 GS-D3 245/45-17
Rim width and height: 5Zigen ProN1 17x7.5"
Rim offset: +48mm
Any rubbing: VERY slight contact on rear stock strut, only from one small protruding ridge on tire, basically only made a small scratch <1mm wide through the paint on the strut, only occured immediately after installation and haven't observed any signs of wear on the tires whatsoever and no further wear on the strut after 15k miles.
Suspension: Completely stock '05 FXT suspension all around
Using any spacers: no
-Steve
Discussion starter · #28 ·
Thanks sjwelna. I'm going to update this sometime this evening.
Discussion starter · #29 ·
Discussion starter · #30 ·
Everything so far is now up to date, and I attached the file in post #1.
As it states in #1 the title of the spreadsheet is when last updated.
Thanks for your input everyone.
>>>MAX
Tire brand and size: Falken Azenis 615 245/45/17
Rim width and height: Rota G Force 17x8
Rim offset: +48mm
Any rubbing: only rubs the fender lip on hard cornering, I need to raise the suspension slightly (+/- 1/4")
Suspension: Megan Racing Coilovers, wrx specific
I'll add the info for our other Foz too:
Tire brand and size: BF Goodrich Traction T/A 215/60/16
Rim width and height: stock Forester S alloys
Rim offset: +48mm
Any rubbing: rubbed on the fender lip under hard cornering/weight transfer in the beginning; now that they've been worn down a little they seem fine
Suspension: WRX wagon struts with Prodrive springs, 20mm WRX sway bar
Discussion starter · #33 ·
To the top!
I just updated the last two. So we are up to date.
Thanks for everyones input.
>>>MAX
just wondering, what is the widest width tire that can fit on the 05 F XT? I was offered free, a set of 275/40-17 kumho v710's for autoxing. I run in ESP and would love to have R compounds. But, my gut tells me that they are way too big.
Discussion starter · #35 ·
Not sure~ I remember there being someone on the forums here with real wide tires. Over 245 for sure. I tried to search, but numbers are hard to search for here!
Maybe someone else will know. In the mean time, if I find it I'll let you know. I'd like their info in my spreadsheet!
Discussion starter · #37 ·
I'm posting Ploney's info to incorporate it into my spreadsheet. If there is an issue, I'll gladly take it back off. But since I found it here:
http://www.subaruforester.org/vbulletin/showthread.php?t=12519&highlight=275*
I figure there is no issue. So the following is from the above linked thread.
Tire brand/size: Kumho V710 275/40-17
Rims width/height: Enkei RPF1's 17 x 8
Offset: 35
Rubbing: No major rubs, but front will need some trimming
Suspension:Megan racing WRX Coilovers, 8K F, 10K Rear, 14.1 inches from fender to center of wheel ride height wise. Rolled fender lips.
Spacers:NO
Discussion starter · #38 ·
Just updated the file with my info. I had a tire blowout forcing me to install my rims/tires...Darn
Also I added a not in the first post.
Thanks everyone.
Tire brand and size:Hankook K106 225/50/16
Rim width and height: 04 FXT wheels
Rim offset: ?
Any rubbing: none
Suspension: JDM Ver.8 STi take-offs / STi 20mm rear swaybar / Whiteline rear strut bar / -2.5 degrees camber & 0 toe in the front / -1.0 degrees camber 0 zoe in the rear
Tire brand and size: Falken Azenis RT-615 245/45/17
Rim width and height: 5Zigen FN01R-C 17x8
Rim offset: +48mm
Any rubbing: none
Tire brand and size: Toyo Proxes4 225/45/18
Rim width and height: Volk CE28n LE 18x7.5
Rim offset: +48mm
Any rubbing: none
Suspension: 04 USDM STi struts and Tanabe GF210 springs (04 STi application)
Do you remember who was running this? I'd like to know how much clearance they had. If I got +50mm offset 18" wheels that would be about 2mm less... would it be too close?
