41 - 60 of 1208 Posts
30 Meters
2006 XTi - VF39 Protune!
Discussion Starter #41
That was probably DOHCammin if he submitted it. If it isn't his setup maybe PM him and he'd know where to find out more.
Or if he checks the thread, that'd be great so we can have the communication here.
2004 Forester XT MT
Tire brand and size: Falken Azenis RT-615
Rim width and height: 5Zigen FN01R-C 17x8
Rim offset: +48mm
Any rubbing: none
Suspension: JDM Ver.8 STi take-offs / STi 20mm rear swaybar / Whiteline rear strut bar / -2.5 degrees camber & 0 toe in the front / -1.0 degrees camber 0 zoe in the rear
Using any spacers: no
What is the size of the RT-615?
Tire brand and size: Bridgestone Potenza S03 235/40/18
Rim width and height: Rota Formula Mesh 18"x8"
Rim offset: +48mm (I think)
Any rubbing: none
Suspension: New WRX Wagon struts/spring
Ol' Timer
2006 WRX Spec-C 6MT
Tire brand and size: Bridgestone Potenza Re 960 PP 225/55/16
Rim width and height: Stocker 16"X7"
Rim offset: +48mm
Any rubbing: none
Suspension: Swift Forester springs / Perrin FSwB / STi RSwB / HD mounts / KB F&R endlinks / STi Rear L.L / F&R StB / H-brace
Got a quiet car? No? Contact me :-)
96 Tacoma
Winter:
Tire brand and size: Hankook W300 225/50/17
Rim width and height: 7.5x17
Rim offset: +48mm
Any rubbing: none
Suspension: stock
Summer:
Tire brand and size: Bridgestone RE-01R 245/45/17
Rim width and height: 8.5x17
Rim offset: +44mm
Any rubbing: none
Suspension: Megan coilovers moderately lowered
Race:
Tire brand and size: Kumho V710 275/40/17
Rim width and height: 9x17
Rim offset: +35mm
Any rubbing: none
Suspension: Megan coilovers, moderate height
none none
-Tire Size- 235/45/17 General Exclaim UHP
-Rota Tarmac 2 17x7.5
-+48
-None at rest, possibly slight rubbing when really pushing the car (not much room to the rear strut bodies, but enough that a 245 of this tire would probably still barely clear)
-Suspension -entirely stock
2005 forester xt
Tire brand and size: 225-50-17 michelin
Rim width and height: ROTA REV 17X8
Rim offset: +48mm
Any rubbing: none
Suspension: JDM FSTI TAKEOFFS.( i have about 1/4 inch space between rear tires and shock housing
07 Forester XT
Tire brand and size: Yokohama A032 245/40/17
Rim width and height: Rota Torque 17"x8"
Rim offset: +48mm
Any rubbing: none audibly noticeable
Suspension: 04 USDM STi struts/ JDM Pink springs / Group N Top hats
Test fit these today at a buddy's place. Went for a drive and put them through the paces around some hard corners and a few bumps. No rubbing sounds whatsover. I would estimate there's 1 3/4 inches of space between the tire and the strut tower, can barely get two fingers back there. Might be sketchy getting 255's to fit.
2007 XT Sport
Input needed: I have an '07 XT Sport, and wanted to run an 18x7.5 wheel with stock struts and Swift springs.
Offset and tire size recommendations, please?
Thanks.
Edit: Forget it, I think I've figured out what I need.
I'll add another one:
98 Forester S
Tire brand and size: Bridgestone Potenza RE92 215/50/17
Rim width and height: stock Legacy GT wheels 17x6.5
Rim offset: +55mm
Any rubbing: none
Suspension: WRX wagon struts and WRX-specific Prodrive springs
2005 Subaru XT
Tire brand and size: Dunlop Direzza's 225/45/18
Rim width and height: Volk CE28n 18x8
Rim offset: +44mm
Any rubbing: Nope and no gap at all :)
Suspension: BR Coilovers with PU Mounts and front camber plates
Using any spacers: Nope
