You don't need any special tools to remove the quick connect fitting on top of the fuel tank. I just used my fingers. :wink:
You can view my filter & fuel pump write up
here in my Member Journal.
A special release tool, you can view mine
here is required for the fuel line fittings in the engine compartment, but not the ones on the fuel tank.
'07 FSXT MODding Journal] [
'03 X MODding Journal]
Thanks, in fact your write up is the one I've been using as a guide. There are some differences however:
The fuel pump tank flange on mine only has two lines out, one is a vapor line that has a spring clamp and the other is a fuel delivery line that has the retainer. It will NOT come off without the tool, and in fact it is the same fitting as the engine side. Additionally, in my manual the disconnect is shown to be the same part and the retainer is shown to be the same part, both ends.
Could be the difference between T and non-T?
Could be changed when the recall was done?
Could be a later or earlier model, same model year?
I don't know, just know I need to get this 0442 found and fixed cause it is driving me crazy whenever my cruise drops out in the middle of a trip.
By the way thanks for the info on not tearing up the clips or panels when removing the rear deck panels. I don't have to worry about that, the dealer already broke them all when they did the recall and never replaced them.
