ECU Temp sensor
14K views 86 replies 12 participants last post by  Pondman
Hi guys
When I first start my 2.5XT it idles perfect etc, however when i drive for the first mile it bucks/hesitates quite a lot.
There are no codes and when warm it drives better (albeit still hesitates sometimes). Does this sound like a possible ECU temp sensor?
If so where is it and is it a slag to change lol ?
PS I have an OBD II wifi unit running Dash Command , this has coolant temp readings but are these for the ECU or for the guage? any help would also be appreciated on this..
Many Thanks
#2 ·
Hi,
This is the AIT (Air Intake Temperature Sensor). Its usually logged by the ECU so I am surprised that it is not showing as an option in Dash command, but could be something to do with Dash Command.
I'm pretty sure that with your car the AIT is part of the MAF.
#4 ·
Right,
Didn't quite understand what you were asking.
Engine Temperature is a separate sensor that does indeed check the coolant temperature and is located in the block:
http://www.subaruforester.org/vbulletin/f66/coolant-temperature-sensor-location-6734/
'are these for the ECU or the gauge?'
Your OBD2 connection will tell you what the ECU is seeing.
I'm pretty sure that the gauge in your dash gets the reading from the same sensor as there is only one.
#7 ·
Yep, when I do search on FAST for all the parts containing the word 'sensor' there is only one coolant/engine temperature sensor.
Googling around there were two on the '98 one for the dash and one for the ECU but I don't think that is the case anymore.
#9 ·
Hi, you and I have exactly the same V. irritating issue!
I'm fast coming to the same conclusion that it is temp related too. I now have a set of cam sensors to fit (as and when). This issue has been driving me crazy enough, to swear at the car! :Banane36:
It just spoils the overall driving pleasure, as you are just waiting for the next cough or hesitation. I have replaced the MAF, so I can't see it being that. If the car is left to warm just for 2 mins before pulling away it does not seem to do it, at least, only a little, little bit. But the hesitation under light throttle increase is still there. Maybe between all of our heads we can put this one to bed once and for all. Please keep this tread alive and updated, I'd dearly love to solve this issue. :icon_wink:
#12 ·
Have you guys tried buying a £10 VAG OBD2 cable and connecting the car up to a laptop with Romraider installed?
You could log knock sum, AFR, Advance and AIT to understand if it was a dud sensor sending signals to the ECU or something more mechanical at least.
#16 · (Edited)
I think I'll remove the filters in the banjo bolts (15194AA270) to see if this improves my AVCS action. It may be that the the AVCS does not get a decent oil supply until the oil warms and thins a little. When it has warmed maybe improving its effectiveness :icon_question:
This might lead to the cold start lurching :icon_question:
The neutral switch apparently only effects tick over or non-throttle driving, my issue is under light to medium throttle when cool or a slight hesitation on throttle depression when warm.
#22 ·
Removed mine this lunch time. Easy as pie, less than a 20 minute job.
Mine were pretty clean to be honest, they had dropped into the the oil way though, and I needed a pair of forceps to get them out. I wiped off the banjo bolts inside and out and put them back to the same position.
I've yet to drive it cold which I'll do tonight and feed back the findings. Apparently they only put these filters in early AVCS cars and removed them on later models with no ill effects.
I was sort of pleased and, not, to see that they were clean. It means that oil was flowing and good maintenance had been carried out, but I don't think it will make a difference as the oil was probably getting through.
#24 ·
As this was an experiment to see if made a difference I used the original washers. I'll keep an eye on them over the next week or so.
But I have to report I noticed no difference in cold driving behaviour, still lumpy and chuggy :confused:
I even tried putting the cruise control on to see if when I wiggled the "shifter" aka the gearstick. To see if the neutral switch would cut the cruise off. It didn't. So I assume that the neutral switch is also ok? But it did start in gear and I thought that if the switch works it would not let that happen :icon_question:
Next!?............:confused:
#25 ·
My defective NPS only showed up on Ecutek whilst vehicle being mapped.
It would cut in and out randomly. Was one of the parameters being logged so could see it happening on the trace screen.
#27 ·
Don, been mapped at Tractive Solutions, no codes were found to be present that effected running. but is does not seem to be a pricey part so it might be worth a punt?
SiPie, about a year ago for a colder running set to handle the increase in boost pressure for the impending mapping.
#29 ·
Assuming that the rebuilt and forged engine (by API) is still performing OK, it's only done 10k since it was rebuilt, so compression is assumed to be OK.
Knock sensor, well no dash codes or lights have flashed up as yet. I have an OBDII handset and it shows no current issues :confused:
#30 ·
Really strange one this as I still get the jerky running from cold but only for first few minutes, then all is fine with no signs of hesitation anywhere throughout the rev range on full or light throttle etc... I now treat it as just one of these things and let it warm up gently.
Can only wish you the best of luck as I know how annoying this is, even more so for you considering you are on a relatively new engine.
