This seems to be the cause of the knocking i get upon cornering right. It's on the drivers side. As you can see it has fluid leaking from it. when I poke a screwdriver in there and waggle it about, there seems to be a lot of play.
As far as I can see, there are 3 seperate bushes that hold the control arm (wishbone?) in place.
I only seem to be able to find poly bushes which are rather expensive.
