Although Stan thought they were pretty nice and Superacerc reckons they will handle better, personally, I think Foresters running around with smaller profile tyres on stock rims look a little silly as there is a big gap under the arch. As far as handling goes, a stiffer side wall will make the cornering feel tighter under pressure but the there is a trade off. The lower the profile and stiffer the sidewall, the more noise will be transmitted into the car along with increased effect from road defects/seams etc. There is a reason why the older Rolls Royces and othe luxury cars were running around on 70+ profile tyres, comfort and noise reduction.
The smaller rolling diameter of a lower profile on the stock rim, unless you expand the width out to 235/245 (if that's even possible, relative to rubbing) will also highlight and exagerate undulations and potholes as well as increase noise from the larger footprint. On top of this you have the gearing issue. If most of your travelling is urban, then I guess it doesn't matter but if you do sustained highway driving (60mph+) on a regular basis then the reduced gearing of the lower diameter wheels (225/45/17) will become irritating and tiring because the engine will be working at a slightly higher speed than before for the same given speed. The difference between 110 and 120km/h (that's only a 6mph reduction) in my Foz on the motorway has quite an impact on longer journeys, engine/exhaust/tyre volume wise and while some of the guys over here are geared for a maximum of 100mph in 5th on their Imprezas (diff setups) and go "whoopee look how instant the throttle response is in 4th and 5th" :icon_rolleyes:, if that sudden surge is needed, surely you can drop a gear? Some of them who travel distance will admit though that noise becomes a real issue after about thirty miles, as well as fuel consumption, I should imagine.
If none of these things seem relevant to you, go for it but as a word of warning: This really good AWD setup we have is unforgiving of anything but good tyres and while many boots would be fine on pretty well any 2WD car, your Foz may not like them, and that's a costly experiment. It might also be an idea to check out what's actually available in your region. Over here, not so much for my OEM profile (I'm on 16"s) and I had to order the Avon ZV5s I now have and am happy with. Over there, you have a much bigger market so I expect most things are available. Perhaps an online tyre/rim size calculator and a look in the tyre section of the site might help?
