Any way to fix/improve cabin noise/vibration?
1 reading
13K views 10 replies 8 participants last post by  SuubMarine
Wasn't really sure where to put this thread. But after driving a few of my friends newer model wrx's and foresters, I get really jealous of how solid the car is, especially when going over rough roads, bumbs, turns, etc.
My 2008 fxt has 95k on it, and its most noticeable by how loose and noisy the cabin is while driving. Even on slightly rough roads you can here vibrations, clicks, clacks, all that...mostly in the rear/trunk area. And sometimes during turns you can here a "creaking" sound like the body is separating from the frame.
I've been looking into rear and front sway bars to help the feel, but i'm not sure if it will help any of the noise. I have upgraded suspension so the feel is nice and firm, its more of the vibrations and noise that i'm talking about. It could be that the car is just getting old, things are getting loose...but I want to know if people have ways to help and improve that. Thanks, any advice greatly appreciated!
#2 ·
If there are already threads that address this please forward me to them. Sorry if this has been asked numerous times, I did some quick research but wasn't sure if my exact problem was being addressed. Thanks a bunch!
#3 ·
An 08 should hardley feel creaky by now (this is coming from a guy driving an 01 thats been stripped down and put back together, inside and out for a swap) ..
Usually the creaks occur when panels arent put back together correctly or things are left loose. I spent MONTHS chasing down noises and remedying them with the following:
-(shinitzu) Greasing all doors and trunk hatch weather stripping
- Applying noise dampening materials into areas where gaps existed behind panels
- Applying sound deadening material to the cabin interior itself (this takes work)
- Getting under the car and applying polyeurethane grease spray to each and every bushing and suspension component joint.
- Applied sound deadener to my gas tank underside.
Following those guidlines from threads on here, i was able to make my 01 SF5 , even after full STi swap, upgraded susp components and BC coilovers, quiet as a mouse again on the inside.
#4 ·
I just bought an 09 with only 36k miles and I love everything about it except it is the noisiest car I've ever had. I'm also having a bunch of creaking and rattling and clunking coming from the rear passenger side of the cargo area. It's hard to pinpoint where it's coming from when I'm driving, so I'll have to get someone else to drive while I sit back there sometime. There's also a bunch of rattling from the front suspension or engine compartment whenever I hit small bumps or just drive down a dirt road. The end links are sometimes to blame, but mine are tight. Short of hitting everything with a rubber mallet, it's hard to figure out where the noises are coming from.
#5 ·
As Mike says and when you have decided everything that should be tight is so, search for "SeaScoobys" excellent article on soundproofing/deadening. I have around 70lbs of the deadening on my car, which is overkill, but it is substantially quieter than when I got it. The SF series were very poorly insulated but the later models got progressively better however, they still aren't on a par with a modern saloon car in my opinion.
The worst offenders are the panels at the back of the car, the trunk and rear quarter panels (over the mudguards) along with area around the spare wheel well. Applying sound deadening to these panels increases the mass thereby reducing/lowering the resonant frequency to a point where it's no longer annoying, sending it down there with tyre roar and transmission sub bass. Anything below about 40Hz is acceptable to most folks but if you have big fat tyres, then the 40-120Hz region is dominated by their 'roar' hence the propensity for installation of sub woofers in modern cars/cars with wider tyres, to claw that low bass back.
Carefully pull the trim on the side panels in the trunk and lay some sound deadening on the outer skin, tapping on the outside till you are happy with the "thunk". Next you need to stuff the rear quarter panel space really tight with something absorbent, SS recommended the filling from really cheap and nasty (do I hear Walmart?) pillows and I can vouch that it is economical and works. At least one pillow per side and at probably more than one for the trunk lid cavities (I'd buy at least 4-6 pillows)
Pull the trim from the inside of the trunk door and again, lay some sound deadening down using the tap method on the outer skin. Once that is done stuff the remaining space with the hollow fiber but making sure you don't foul the pathways for the locking and wiper mechanisms. Apply some sponge to the back of the main trim plastic panel as well because that's hollow too. Careful with the trunk lid though because if you go too far (I mean really too far) the struts may have trouble supporting the extra weight. I have loads of deadening and stuffing and the lid needs assistance to lift (just a little) but stays securely where it is at the top, it also closes nicely without needing to be banged.
Lift the rear flooring and remove all the ancillaries under it. Line the floor space with sound deadening and fill any obvious spaces with stuffing.
As a rule on applying sound deadening, tap the panels and if they sound hollow apply the matting. If the metal already sounds solid, you are probably wasting expensive materials. I did as far as under the rear seats and some big square panels under the carpets where the feet would lie.
Subarus have rather thin sheet steel on the older models, not sure about the newer ones but pulling the door cards and protective film will allow you access to the inner and outer skin. Some folks just plaster the inner skin and leave the outside one, which doesn't make a lot of sense to me. Again, use the tapping method to determine how much the panels need but be aware that this material is quite heavy and if you go overboard (complete coverage, doubled), the door hinges will eventually start to sag.
If you can release any of the other trim panels that don't have moving parts behind them, like the trunk trim around the side windows, hollow fiber can be stuffed in there as well but be careful about jamming up the fixing clips with it.
I did the under side of my hood too but couldn't say whether that has been a success or not. Some guys will say no way you should be adding all that weight but in the overall scheme of things, sensibly and judiciously applied sound deadening would equal a weekly shop or the crap a lot of folks permanently carry in their trunks anyway.
It is also worth bearing in mind that the Forester is sitting on a permanently active AWD (unlike many so called "AWD" cars that are mostly 2WD), often with larger tyres fitted, and that noise will be transmitted into the car. This was apparent for those of us who as children found the back of the family car uncomfortable and noisy, but when the majority of cars moved to FWD from RWD in the late 1970s, all of a sudden, the back seats were the place to be now the rumbling prop shaft and diff were gone. Comparing this scenario to something like Jaguar or BMW though requires you to go and lift the floor insulation on one of these cars and see that it's a big deadening mat, usually at least 2.5" thick (Jaguar anyway).
And a small tip when applying sound deadening (like Raamat or equivalent), wear heavy gardening type gloves and use a ball ended hammer, around 3-5 pounds, for pushing the adhesive matting into the panel mouldings, like the trunk floor. As most of these mats have a bitumen backing with a thin aluminium type front, your bare hands will be cut and marked quite badly without you realising.
#6 ·
Last fall, on my new 2012, I did the Rammat on all doors and hatch. Made a big improvment. I hope to do the spare tire area, gas tank area, and under the rear seat this spring.
I started to do the spare tire area last fall, but could not get the (many) plastic clips off, without destropying them. I did not have any spares.
#8 ·
I would add that, if you are not careful ( with the soundproofing), when removing panels, that you could create more squeaks and rattles when reassembling them. The door clips are easy to remove and reuse, but the other push/pull screw type of panel clips are difficult to remove without breaking or stripping them. They would go back on loose, if you reused them. Maybe there is a trick to removing them?
If you have the tweeters, they are difficult (the first time) to remove without breaking the mount tab. I broke the first, until I could see how they mounted. The second was fine.
