Hi,
I was in for my 12k service last week, and my front/rear brake pads are down to 8mm/7mm. This is from the 9/9mm noted at the 6k service.
At this rate, by my 24k service, I will be down to 6mm/3mm. I understand that the rear brake pads tend to get worn first (from previous experience with my last 2 Subies), but it seems like a faster than expected wear.
At the 30k service, if this trend continues, I'll be at 5/1.
For what it's worth, my dealer said they usually recommend a pad replacement any time the pads are below 3. While I'm aware that brake pads are covered through the 3/36 warranty, I'm just "concerned" that the wear is so fast. My Outback and Legacy went around 4 years/50k before they needed a brake and tire job, and the commute is the same.
I'm wondering if the adaptive cruise control has anything to do with the increased wear. I may try driving with the standard cruise and report back after next service in the summer. Or, if the tech didn't measure it exactly correct. We're talking about a millimeter here.
