2017 - How to remove tail light assembly?
34K views 12 replies 7 participants last post by  Kevin
I need to replace the turn signal bulb in my tail light. I removed the 2 screws and the assembly is "loose", but does not want to be removed. Is there a "secret" to this? I don't want to pry/pull on it too hard and break the assembly. Thanks in advance!!
#4 ·
When you say "yank on it", do you mean yank it in the direction away from the back of vehicle? Or, do you yank it away from the vehicle towards the side (passenger side)? Again, don't want to break any tabs that are holding it in place. Thanks.
#9 ·
You are a lucky guy. I have seen those directions, and I already had that much figured out. But it simply did not offer any appropriate grabbing locations, and trying to pull on the outside was fruitless.
#10 ·
Yeah, @bbottomley you might need two people if you cannot pull back. It's different on the 06-08 models but since I see the diagram you pull back regardless. You could spray some WD-40 in there or get a panel clip on both sides of the taillight. It might just be stuck so be careful y'all don't rip out the wiring harness. Wish you well!
