Enough time and miles have passed that the TB was due for a cleaning. I recommend buying a new gasket.
Remove battery negative terminal
The torque on the TB bolts is only 8nm.
Covered the intake from debris.
I used Subaru throttle plate cleaner because it’s very powerful. Cleans well.
I clamped off the TB coolant lines and removed the entire TB assembly.
Cleaned with brass brushes and Scotchbrite pads. All the carbon came off and it’s now squeaky clean.
did an idle relearn and all is good. Now I can do the Top engine carbon clean with the special Subaru tool.
