Hi, guys. I am learning to do some of my own maintenance, and yesterday replaced the serpentine belt and the PCV valve and hose on my '14 Forester with 132K.
The hose that I took out (possibly original to the car, I'm the second owner) was just friction fit with no clamps, and was on pretty good. The replacement I received (Subaru Part #11815AC610) has a spring clamp on either end. Even with the spring clamps in place I can easily pull the hose off both the manifold side and the valve side. It's on there, but definitely not tight. Does anyone know if this is expected behavior? I put the old hose back on for now, but it is quite hard and brittle and I'd like to replace it if I could.
Parts appear to be all Subaru original.
Thanks!
RichieMac
Thanks!
RichieMac
