2011 - Engine knock (video)?
1 reading
617 views 31 replies 7 participants last post by  Monkey627
Vehicle Details:
2011 Subaru forester
I need help engine knocks after warm up but goes away when reaching a certain rpm
#4 ·
If that is engine knock, I'd be heading back to the builder. Assuming proper break-in and maintenance, you shouldn't have rod knock at these miles. It's usually at more than 100k, if that even. I have 190k with no rod knock. Just lower compression.
#9 ·
You have to use a sharing site and link the video unless you use the forum app. This would be Youtube and the ilk. Google Drive and that kind of thing. I use both.
#16 ·
From my limited research when looking for a replacement engine for mine, it seemed that JDM engines typically have a host of different issues, so I went with USDM on mine. Did it come with a warranty at all?
#24 ·
So, if the knocking is only after warm up, what oil do you use? For example if you use 5w-30, try 5w-40, it's not going to fix a mechanical issue, but perhaps it might make a difference. Not a Subaru, but I have an 5.7 LS1 Holden (GM) 2000 model. Oil spec is 10w-30, but it seems better with 10w-40, pretty sure it has less of a taping noise than it did running on 10w-30.
#25 ·
The noise in the video doesn't sound much different than my car. It could be wide valve clearances which I think is an engine out job to fix as the clearance shims are under the buckets not on top.
#29 ·
On our MX5 (Miata) there was a noise that I thought was a failed cam advance solenoid and it turned out to be a flat on alternator v-belt. When you hit the deer did the engine come to an instantaneous stop?
#31 ·
You mentioned that engine shifted on its mounts, what about the exhaust system, I'm wondering if parts of the exhaust are touching body work and engine sounds are transmitted different or exhaust brackets broken or pipes bent etc. since accident with the deer. You mentioned you're using 5w-20 oil try 5w-30 synthetic.
