2010 - XT - Temporary stft
112 views 9 replies 2 participants last post by  4836JONATHAN
Vehicle Details:
Forester
Hello folks. My 2010 Turbo Forester does a weird thing. On any start up, count to 10.
Then stft goes -20% ish. Engine stumbles slightly. Trim comes back around 0 in about 10 seconds. Engine smoothes out.
Possible evap leaking into manifold till the vapors are gone?
Any advise would be appreciated.
#6 ·
Fuel trim numbers are calculated number values based on multiple inputs. They don't really indicate something directly. These numbers are a reaction to the engine not so much a report on the engine. So in your example, a stumble wouldn't be the result of changing FT values. It's likely that the stumble is the result of the ECM driving the idle speed down in a reaction to something it sees in the inputs. You could say like a loose A/F sensor wire or something like that. Or maybe a faulty read from the crank position sensor. FT numbers don't reflect a single misfire, for example.
OBD reports on the EGR valve position in real time if you have a scanner.
#9 ·
It sounds to me that you have a fault that the ECM concludes is not a fault. It may be the misfire. You can check your “pending” codes with a scanner. If you receive a CEL, I recommend you you also review the freeze frame data.
