I recently bought a 2010 Forester 5spd non-turbo at auction. 170k miles. The engine was replaced with a used one out of an 09. When I turn nearly full lock at very low speeds there is a juttering kinda vibration, sometimes making the whole car feel like it is lurching. I have to feather the clutch and give more throttle than normal to avoid stalling. After looking into it my first thought was the center diff failing, but when I insert a 10amp fuse into slot 15 to disable AWD I don't notice any difference in the symptoms. All the tires are the same size and wear. All tires are properly inflated. The transmission/front diff oil is full and appears clean. I have not checked the rear diff oil.
When I install the 10amp fuse to force it into AWD, are any dash lights supposed to come on? I can't really notice any difference at all. I didn't try to lose traction to ensure that the car is in fact being forced into FWD.
1. Is it safe to continue driving the vehicle like this? The problem only occurs at slow speeds while making very sharp turns
2. Could a binding front CV shaft cause these symptoms, and is there an easy way to definitively diagnose which CV shaft is bad on these vehicles?
3. Is it possible the front diff (which as I understand is a part of the transmission) is failing?
4. Could doing the "drive full lock in a circle 20 times in each direction" advice actually help anything? is there any risk associated with doing so?
Any guidance is greatly appreciated. This is my first ever Subaru and I'm hoping I can properly fix this for a reasonable cost.
