81 - 81 of 81 Posts
Discussion starter · #81 ·
Update 2020
I recently purchased a 2011 XT with the plain jane mirror. Someone local was parting out an 04 XT and had the mirror + harness. I took a calculated risk and bought it figuring at worst I'd need a different harness. Turns out, it was all plug n play. The wiring harness plugged right into the car harness underneath the map lights.
Install instructions for 2009-2012 Forester:
Open sunglasses door next to the map lights
Unscrew 2 Philips screws
Pull the entire map light unit down from the front. It's held in by the 2 screws than then two clips, should come out pretty easy.
Locate car harness underneath, mine had black electrical tape holding it to another set of wires and didn't allow for much play so I cut the tape carefully and pulled it free gaining a good 4-5 inches of play.
The rest of the install and programming was the same as the original post
81 - 81 of 81 Posts
