2007 - DIY - Homelink installation guide with pics! - Updated!
1 reading
72K views 80 replies 31 participants last post by  Legacy
#1 · (Edited)
After much waiting I've installed my Homelink mirror. We have a double garage so there's no better reason to get one. No need to keep two remotes stuck on the sunvisor anymore, yay ! Level of difficulty, 3 out of 10. The only two tools you really need are a phillips and slotted screwdriver.
First off the instructions aren't all that great. Sure once you've done it they all make sense but the pictures are cartoon and not the most accurate so at times you're left guessing. Well you're in luck since I took pics every step of the way.
The homelink mirror is different from the OEM and the Compass mirror. It requires a camlock adapter to fasten to the windsheild mount, why I don't know. My Forester came with the Compass mirror. I sold mine for the upgrade, then couldn't find a Homelink so I ran the OEM mirror which by the way fits on the same OEM mount as the Compass.
Before starting the install in the car here's something to do in the house. Note: the instructions make NO mention that you have two different sized screws and where they go. It just says "put them in", thanks.
Here's where they go, actually all that matters is you put the one longer screw in the top. And that's somethign else, the instructions are too cartoon to tell which way to face the camlock. In fact the picture looks nothing like it in real life. Again thanks.
Fasten the cast iron piece to the camlock. It goes in with the bevelled side facing upwards, don't miss that or the screws will stick out further. Fasten the top screw all the way down, this just holds the cast piece to the camlock. The other two pieces will be installed in the car.
Here is the lamo OEM mirror. Time to put it out of its misery
Its removed by twisting the base 90 degrees. Don't tug on the mirror or you risk cracking the glass. Put your hand on the base and twist.
Like this. Then just slide it down and you're done.
Replace the clip with the one supplied with the kit. You may think "why bother", well as I found out they are different enough that the mount will not sit properly with the OEM clip. Check it out, Homelink clip on the left, OEM on the right. Just different enough to make life miserable if you don't do this step. It recommends a screwdriver to remove the clip but you don't need one, I just stuck my nail in there and pulled it out a side at a time.
OEM
New
Then put the other cast iron bit in the clip and push it up all the way. Make sure its facing the right way
Now its time to fasten the camlock to the OEM mount. The two bottom screws will hold it in place. Screw them into the cast iron bit . Don't overtighten, cast iron will strip very easily. Just tight is good enough, this isnt' an airlock in the space shuttle.
DEC 2010 EDIT: After nearly 3 years I found the mirror had some play in it. The source of the problem was the two top screws had loosened over time. It might be a good idea to apply some locktite at this point to avoid this issue. See my Dec 11 2010 post for full details.
Now to run the wiring to power the Homelink. The entire top console has to come off. Start with removing the cover for the lights. Just put a straight edge screwdriver or knife in the bottom (there's a slot) and gently pry out from the bottom then the top.
This reveals the light assembly. Remove the two phillips screws on each side.
Open the top sunglass holder and remove the phillips screw
Now you can pull out the console. I chose to let it hang by the wiring. Its not exactly heavy so you should be safe.
Remove the plastic screw that holds the trim in place. This way you can pull it back to slide in the new wiring harness. You can see my old one is in the way with the green/blue wires.
Unplug the wire harness
From this end
And run the new harness though the headliner. Don't forget to plug it in at the top before you put the console back together. The console goes back to gether in reverse order. Piece of cake.
Time to fit the mirror in place. Just slide it in from the top down. It won't stay by itself without tightening it so hold it with one hand.
#2 ·
You'll need a T-20 Torx to tighten it down. Again, just use enough force to mount it firmly.
Three steps here. First, put the solid clip in place. It hides the ugly wiring. The clip goes in from the bottom first and then the top slides in. Next, plug in the homelink and then fasten the wiring UNDER the C clip on the miror so it looks all neat and tidy.
Wipe off your grubby fingerprints, sit back and enjoy the fruits of your labour. We have homelink !
#23 ·
I don't have a Homelink, but I had a similar problem with wanting to open the garage door before I started the engine. I had a spare 'visor' opener, so I simply made a mount for it next to the door between the house and the garage.
Now, when I walk into the garage from the house, I can just tap the correct button and open either of the garage doors. I guess I could have hard-wired two switches there, but this was so much easier... plus, if I want to go outside in cold weather, I just drop the opener into my pocket and I can close the garage door behind me and let myself back in without unlocking the front door!
#14 ·
Why isn't this in the DYI section???? I went there look'n and it wasn't there.....I had to search to find it....We should move it for others! It was invaluable to my install. You weren't kidding, with your instructions it took me 15 minutes from start to finish and a lil trip to calibrate it......Super easy install, I'd say 1 outta 10.......not 3.
The only add I have, in the step where you have to disconnect the Auto dim mirror, we should mention that if you have a plain old non powered mirror, you don't have to unplug anything, just plug it in.....even easier. :biggrin::biggrin:
Thanx man, I didn't even open the stock instructions......
#21 ·
will this work with MY09 XT Premium? I've ordered from the web last week and I've checked the wiring of the roof console. I notice it didn't have any spare power connector (I saw connections for both lights and sunroof)?? What should I do? Is there some kind of splitter that I can pickup from an auto shop? Any help will be really appreciated!:confused:
#24 ·
I have one of these mirrors standard with the subie from the dealer. It never has worked for me. I cruised thru the manual and didn't notice any instructions for it. I was told that if my GD opener ("garage door"... not, uh....) had a randomizing opener code it would be just an expensive trinket. I have a brand new Genie Pro Max opener on my door.
#25 ·
There is a little disclaimer in the intstructions that you may have to also use the "learn" feature on the garage door motor. This is what I had to do with both my garage doors. Go through the procedures of programming then, on the garage door opener motor itself there's a button to press to associate the remote with the door. Its a security feature so Joe Bloe (and not Joe Boxer) doesn't park outside your house and clone his opener to your door. Took 2 extra minutes and works fine.
#26 ·
Thanks for the info/write up. Another idea I've been considering is converting one of the dummy switches next to the fog light switch for use as a garage door openner. I don't think it'd be that hard, just a matter of finding a momentary switch that fits in the blank.
#27 ·
#32 · (Edited)
Inside rear view mirror info. Autodim, compass etc. - ScoobyMods
Did You read this thread, re:wire tapping into?
Good luck.
Thanks for the link man.. but i still have a couple of questions (sorry!)
I went to Subaru service this morning and they told me that the Tribeca has a different wiring and they can't help.
I then check with local auto shop and the sale staff said their electrician can do it ($66.00/hr). The only concern is the wiring on the 3 pin plug. Since all 3 wires are black (one with white strip), can anyone tell me which one is which?
The info i gather from other forum..
Ground for the centre black
Homelink for the black with white strip
Auto-Dimm & Compass for the remaining black
Is this correct?
Also I saw they all run wires to the fuse box to get the power.. is this a must or can I just tap into the switch that connected to the roof console?
#33 ·
I finally got around to trying to install my homelink mirror tonight and I cracked my damn windshield.
I was trying to fasten the adapter piece to the existing windshield mount. I don't know what the problem was but the adapter would NOT fit correctly over the mount. It kind of fit over it but it was easy to tell it was not on all the way; it was not flush to the windshield and I could not get the middle screw shown in the last pic of this post to thread in at all, no matter what I tried. I could get the bottom one to thread in slightly but that did not seem secure. I am sure it is supposed to fit on there snugly but I honestly think something is not quite right with the adapter I have.
Anyway, I was trying to be careful but I got frustrated and I just pressed too hard trying to get it on, and of course a crack spidered out everywhere. I know I had done everything correctly up to that point so I am baffled. In retrospect I might have tried sanding the adapter down to make the "hole" wider to see if that would allow it to slip over the mount correctly. Either way it looks like I'll be calling the insurance company tomorrow. Argh! :yell:
#34 ·
Just to update: I searched and found that filibence had the same problem I did with the adapter (P/N H501SSA040). This is a different one than Legacy used in this writeup, but it's the one shown in the instructions and the one my dealership sold me.
The thing is just not made correctly. I had to dremel it out at least 1mm wider to get it to fit over my windshield mount. It was never going to fit the first time I tried it which is why I ended up cracking the windshield.
Also as an FYI the plastic wire covers that came with my version of the mirror were way too long so I had to shorten those as well.
#35 ·
I know how you feel re: the windshield cracking. The dealership replaced the homelink mirror on my OBW and cracked the windshield exactly as you described. I think there may be different combinations of mirrors and mounts out there that don't play well with each other.
I say that because the new homelink mirror they installed does not look exactly like the one that shipped pre-installed.
#36 ·
I posted in another Homelink thread, but I just want to make sure it gets clarified. What parts (and associated numbers) do I need when swapping from the OEM dimming/compass mirror to the Homelink mirror? Camlock? Wiring adaptor/harness? That little metal clippy thingy? TIA!!!
-Brian
