Recently my power steering sprung a leak, and did its usual thing when it happens. I crawl under to see if i could see any visible leaks and sure enough. Now, i took a picture of the leak, as you can see, a pipe thats coming out of the steering rack to a rubber hose, is leaking. Now i tried putting some pipe clamps on to see if the previous clamp was bad, but no such luck. This hose runs to the others side of the rack and pinion to the other tie rod. What i need to know is; what pipe/hose is this so it can be replaced, and is it possible to just be able to replace such pipe/house without replacing the whole power steering setup. Thank you.
Also, please dont mind the rust and dirtiness, its ugly i know. Maine winters suck in my kneck of the woods.
