What kind of brake fluid to use?
1 reading
67K views 16 replies 9 participants last post by  abacall
So I recently discovered what looks like algae in my brake reservoir, and the fluid was very black and murky, so I decided to bleed the brakes. I used Gunk fluid.
My question is, do the more expensive brake fluids have better detergent properties? I would like to get everything in there all nice and clean again...
#2 ·
Not the kind that has algae in it! Brake fluids (except DOT 5) are hygroscopic meaning that they absorb water over time.
Spending more on brake fluids will not clean your system. Cleaning and flushing will.
I would siphon off any remaining fluid and clean out as much dirt as possible followed by a thorough flush until the fluid runs clean from the bleeders.
I recommend you change the fluid a bit more often than you have been. Not sure what kind of damage to the seals occurs when it is neglected like this let alone the decrease in braking performance...
#16 ·
Yes, I will be changing the fluid more often. It was the first time I've changed the fluid on this car (had it for almost a year and a half).
After driving around for a while the crap on the walls of the brake fluid reservoir doesn't seem to be dissolving at all, and the fluid remains the same color. Maybe after a while I will give ATE super blue or Motul a try just for fun.
#9 ·
If doing it yourself, ATE blue is great because it is...well...blue. Otherwise I would just use the valvoline stuff, seems to be one of the best you can find without having to order it. The brake fluid really shouldn't have any detergent properties. Do not use DOT 5, the system is designed for dot 3 or 4, unless otherwise stated in the car.
#10 ·
I like ATE superblue for the blue color: easy to change if you have something else in there.
Others said it absorbs a lot of water. I don't know, but my experience may bear that out: the other day I had what I think was boiling-fluid fade. Reduced braking, soft pedal. It was dark so I couldn't see if my pads were smoking or not, but I'd driven down the same long steep hill on the same pads & fluid several times before with no real problem. I've only had the Superblue for 8 months, and as far as I can tell I need to change it already. Maybe it absorbed too much water, maybe I've overheated it too many times in the 8 months of street driving.
Not sure what to install this time. Read mixed things about Motul 600 here. Maybe I'll just buy the cheapest DOT 4 fluid.
#12 ·
Might have gotten some moisture in the system while bleeding. ATE is pretty good stuff, and should last longer than that in a sealed system.
ATE also makes the Blue in Red, so when you flush your blue, you can see the red.
#13 ·
I thought ATE only made Blue and Gold? They make red now too? Awesome!
I use Motul. It's about the same as ATE, but it's more readily available in smaller containers. Since you can't store brake fluid, why buy a 1 liter can for $20 if you are just doing a quick bleed?
#15 ·
I just bought a bottle (1 litre) of ATE Super Blue brake fluid......from what I have heard, it's one of the best available & long lasting too. Got it from E-bay for a great deal. I was not able to find this stuff in any auto parts store in Ontario. :biggrin: Gonna do the brake fluid flush in the next couple of weeks.
