I've had the new Tepui roof top tent mounted on my Forester for awhile now and have used it a few times too. Very happy with it so far! It takes just a few minutes to open up and about twice as long to fold it back up, but I am getting faster each time I do it. There are possibly a few things that could be better and some things I will improve as I see fit. Overall, it is a great tent and a good value.
The Forester drives fine with the tent, maybe even better with some extra weight which defies logic, but the dash rattles more (?). I have not driven it far enough to get a good idea on mpg loss. I'm sure there will be some loss but so far doesn't seem horrible.
The 2.5" mattress is comfortable enough for us. Nice views up top and good air flow with 4 windows/screens and just plain cool being up off the ground…...Like a tree house on wheels.
To alleviate one known problem, I've added a 24"W x 40"L piece of 6061 T6 .050" aluminum underneath the ladder. This was to prevent the ladder from denting (or worse) the thin platform skin. Using 3m outdoor tape to stick it down I was able to catch three ribs (12" OC) and then taped across the ends. Now the ladder has something a bit stronger to rest on while driving down the road.
I still need to add a battery powered LED light inside, a hanging gear loft shelf for shoes underneath the ladder outside and maybe a shelf inside too.
The decision to use my already owned Sub oem aero bars under the tent was not so good. One bar at the sliding plastic clamp joint already shows signs of fatigue and is sagging. Ordered some Thule crossroad bars to replace them.
***After closer inspection, I found that the slightly sagging clamp joint was actually loose! So, tightened it up all is well. Still plan to change out to the new Thule bars and feel that they are a bit stronger since the bars are sitting on top of the rails.*
Here are a few pics :smile2:
