Question about the plastic air dam under the engine?
4.2K views 7 replies 7 participants last post by  schan1269
On my 1998 Forester there is a plastic air dam under the front of the car. It looks liek it protects the engien bay from gettign crap up an into it from underneath.
I also assume that this dam is used to help the car in an aerodynamic sense.
Well my 98's air dam has seen better days. I have 3 bolts and plastic wire ties holdign this thing on. On top of that there is a crack in it so one side must be catchin air and causing an aerodynamic bad spot.
Question is does this thing really do a whole lot aerodynamically? Could it be removed without causing me any problems? (I would like to maximize gas milage)
#2 ·
I have never heard anything about the aerodynamic properties of the air dam. As far as I know its primary function is a skid plate/debris protector for the engine compartment and exhaust manifold. From my auto cross and track day experience a ton of people remove them for the after market aluminum ones for better protection. It is such a pain to remove it on my STi to change the oil but I am willing to say if you dont use one you wont hurt anything or notice a decrease in gas mileage.
#3 ·
I think it does have an aerodynamic purpose. In my experience driving without it has a negative impact on mileage.
#5 ·
Anybody else? Also do you know where I can purchase one of the after market aluminum ones for a 1998 Forester?
I think the plastic undertray primarily serves to keep the engine clean, and secondarily allows air to pass under the engine more aerodynamically. The car is designed for use in mud and snow, and the boxer engine hangs low with the convoluted headers and heat shields on the bottom. They are close to the road and exposed to road dirt and tire spray. That area will become a dirty rusty oily mess sooner without the shielding.
Over time, oil changers lose and/or damage the pop screws and plastic sheets of the OEM undertray, which begins to hang down and come off. To replace the whole system is over $200, and you can get a front skid plate for about the same.
Here is a source and a thread on skid plates:
http://www.get-primitive.com/
http://www.subaruforester.org/vbulletin/showthread.php?p=322382#post322382
You can probably find a used undertray, as people who install skid plates often set the undertray aside for sale.
#8 ·
Making your own...
Bottom pan/protector/skid plate isn't very hard.
If you have a state highway garage close, go ask if they have any scrap metal laying around. They probably do.
Even if you have to buy a sheet of aluminum, it isn't that much.
A reasonable drill of 8amp(more the better) and a drill bit for metal, even if you have to buy both...I'm sure the drill will come in handy later(I just bought a 10 amp DeWalt...giggity).
The biggest issue is what to cut the aluminum with. Shears aren't exactly cheap...but...
Even if you have to buy a sheet of aluminum, the shears to cut it with...and the drill bit. You are still less money than buying one and having it shipped.
