Hello there!
I have a JDM forester s/tb '00 year with standard engine and turbo.
It suposed has 240 hp with japanese specs. It boost 12 psi stock
Im using my forester for offroad sand dune climbing, and actually im trying to put a Dual range gearbox.
Because i need the most torque at low rpm and quick spool up for the off road
i need to change the oem turbo for a nother. I read that the VF38 has goos low rpm torque and starts sooner than other turbos.
I know that that kind of small turbos, have the drawback of not much power (over boost) but i dont need more than the OEM power, just need a turbo thath breaths at low rpm better than the oem.
SO precisely these are my needs:
FOr a 2.0 ej205 engine i need full bost to be 12psi (and maintain till 6000 rpm), but i need those 12 psi the sooner i can (at lower rpm posible) DId the td04 be the best for this job? or there is a better choice?
Any ideas?
My ride with 275 60 15
Thanks for the help
Any ideas?
Thanks for the help
