I replaced my HG and now I've got a leak from the driver's side cylinder head that is letting more oil go by than the old HG was. The leak is somewhere near the front of the camshaft which led me to believe it was a faulty camshaft seal.
A little background: The heads went to a machine shop while I had them off. The machinist did the tear down, clean, decking and reassembly. New camshaft seals were installed.
I spent the weekend removing the timing belt and cover to inspect for the leak. I found that the camshaft seal looked clean and dry but I replaced it anyway. Next I inspected the variable valve lift solenoid and gasket but that looked good too. Now I'm at a loss for figuring our where the oil is coming from. I'm not familiar enough with these engines to know where in this area I should be looking.
Any advice on where I should look? And is it going to require another weekend of teardown/reassembly?
Thank you!
Thank you!
