Got 06/07 WRX 4 piston calipers, Hawk HPS pads, and OEM 06/07 rotors installed today. Was a direct 100% bolt on with no modifications. Down the road we will do slotted rotors too.
OP said he put pig-eye WRX rotors on as well. Just means that the caliper mounting points haven't moved.Did you fit the WRX calipers on 12.4" stock size Forester XT rotors? If I remember correctly, the WRX 4 pots originally were fitted over 11.6" rotors.
You guys are over thinking itEven the OEM calipers are more than capable of hauling down a Forester, let alone the 4 pots. Now install a good set of pads and purge the brake fluid, so it's fresh and air/moisture free, then you'll have nice brakes.
