@DanPurcell I did a similar mod on my 2014 Outback. The idea is that you tap off of a wire going to a single existing horn. If you tried to 'drive' your new horns directly with the existing horn circuit, you would not be able to deliver sufficient amperage to properly operate your new high output Hella units. So you just use the existing horn wire as your "trigger". You can even leave your existing horns for additional volume and a clash of tones.
You run that trigger wire to the relay's coil circuit. On most automotive relays, that will be Pin 86. Pin 85 is the coil's ground connection.
Pin 30 is your new line to the battery that will power your horns. Don't forget to add a fuse to this line for basic safety! Your load, or new Hella horns will go on either Pin 87 or 87A. One of these is normally an open circuit (off), the other is normally connected (on). And yes, I've seen relays produced with marking swapped, so you might find you have to reverse them.
