21 - 36 of 36 Posts
long handled box wrench.
I changed the oil a couple days ago and am not under there right now but I think a box wrench would need to have a bend in it, because the bolt is so far in, and then when you flipped the wrench over to go in the other direction, the bend would be the wrong way. So I’d need to find my wrenches that don’t have ratchets in them. Anyway I’d still need to slide in enough so I could see what I’m doing. I’ll check again in about 10,000 km.
With a drain valve the tool discussion is a moot point.
You don't need any tools to drain the oil after it's installed.
Clearly a long handled box wrench is superior.
With the right box wrench, I can have that oil change turned around and the next billable customer on the rack before my competition... eh.... er.... coworkers have their sockets clipped in.
I'm not interested in the geometry of the drain plug when I'm done. That's for the engineers. As long as the card reader says "approved" then I'm good. Neeext!
And a man comes on and tells me
How white my shirts can be
Well, he can't be a man 'cause he doesn't use
The same drain plug wrench as me
I can't get no. No no no.
Hey hey hey. That's what I say.
The days of using manuals are gone. I look up how to do oil changes on AI.
For future reference: The current Subaru oil filter is 15208AA21A. The 20A left the building early this year.....
Reactions: j3rf
The OEM filter that came on my ‘23 is 15208AA160. It’s the black one made by Tokyo Roki. I’ve been able to acquire these since 2023 and still have a few in inventory. Is the 15208AA21A the official OEM replacement?
I have one (not the right size for Sube oil change, albeit) straight ratcheted wrench with offset bends on both ends - 2 dif "socket" sizes. Ratchet direction is changeable on/off with a flick of a small toggle on either end. Think it was from Sears be4 they closed down. So they do make (made?) them. FWIW - I had to use my Makita driver to loosen the plug on my 1st oil change last weekend. It was on way too tight. Torqued it back in place when I was done. 14mm plug.
FWIW, oil changes on a Forester can be an entirely tool-free, jack-free, ramp-free endeavor. They are for me, anyway, and I have ALL the tools. Just get an oil drain-plug valve -- whichever model you prefer. I got a Valvomax, which I highly recommend, but any reputable option is better than the standard drain plug. I'm a fairly large human, and I can get my head and arm under the Foz easily enough to rotate the hinged plastic oil-drain cover out of the way, unscrew the Valvomax cap, and then screw on the Valvomax drain tube, all WITHOUT needing to lift the vehicle (granted I'm usually working on a clean garage floor). It honestly couldn't be easier, and zero tools are required.
I've been working on cars for 30+ years and IMO the Valvomax (or equivalent) is the single best DIY mod you can make.
I second the Valvomax. I’ve put them on my Forester and two Hondas in my family.
After I used up my dealer oil changes, I purchased the recommended 17mm replacement plug. During my first change I was surprised to see the dealer had already switched the plug without ever mentioning it. Next change I put in a Fumoto Valve.
@j3rf
Good info! Sounds like you've got some experience with the oil drain plug on those engines. Yeah, verifying the size ahead of time is a great idea, especially with the potential for the 14mm to round off. Having a 17mm replacement on hand or considering a Fumoto valve are solid plans B's. Appreciate the warning about the potential difficulties with the 14mm plug!
It's important to not over tighten the drain plug and crush washer and strip the threads on the drain pan. The torque is 31 ft lbs. A torque wrench from harbor freight is quite reasonable.
Discussion starter · #36 ·
The trick would be to find a decent torque wrench that spans 30-90 ft-lbs so that one wrench could be used for both the drain plug and the wheel lugs. Ive heard that torque wrenches are less accurate at the edges of their ranges.
21 - 36 of 36 Posts
