2019 - SRH LED headlight wiring diagram help? - SOLVED!
3.4K views 1 reply 1 participant last post by  OuchDamn
Hello there I was wondering if somebody out there might possibly be able to share the wiring diagram for the steering responsive LED headlights for the 2019 Forester if they happen to have it.
I am wanting to install a small light bar and have it switch on and off with my high beams. What I was hoping to do would be to tap the wire that is powered when your high beams switch on, use that wire as a trigger to power a relay that would switch on the light bar from the battery directly. I'm trying to avoid wiring an auxiliary switch for the light bar and have it just come on with the high beams if possible.
This is not as easy to do with this model of headlight versus other halogen models where things are pretty cut and dry. There is a pretty fat bundle of wires going into the headlights and I would really appreciate any help anyone could give as to which wire does what.
If there are other ways to accomplish this same setup by going another route I would love to hear what you have to say. Thank you in advance for your help!
