Hey guys. Today I finally put on my new wheels and tires. The wheels are Motegi MR274 17x7 5x100 40mm offset. The tires are Cooper Discoverer AT3 235/60/17R. I wanted to point out that this is about the biggest setup you can get away with on stock ride height. There is very little (~1/4") clearance while wheel is full turn. Also, as pictured below, you will see there is very very little room between the tire and the strut (~1") and also the wheel and the caliper (< 1"). I know there is a wheel/tire setup database somewhere that this should be filed under, and I trust the mods will help the info find it's way there (Thanks!).
