2017 - Lifetime wheel alignment purchase at Firestone - worth it?
1 reading
13K views 50 replies 27 participants last post by  CLe4R
Hi,
I plan to change my tires soon (almost 49k on my stock Yokohama Geolander) plus the Subaru dealer recommended a wheel alignment at 48k service which I declined.
Is it worth purchasing lifetime wheel alignment at Firestone for $199?
I will keep this Subaru till it dies on me :p. Just want to check others experience using Firestone for wheel alignment and it's worth.
Thanks.
#6 ·
Alignments are only needed if you slam a curb or pothole or suspension work has been done. It's been nearly 5 years since I have done one on my 2001 Subaru. My 2014 Mercedes has not needed one since I bought it used in 2016, the 2013 Nissan Leaf has not had an alignment since new. IMHO, alignments are a big money scam, worse if Firestone or wherever one has the alignment done does a poor job.
#7 ·
I got one for my coupe. I've gotten more than 2, so it was worth it for me. The one I used to go to also had a guy who actually cared about cars and would take his time with the alignments. He's since left and I've noticed that they tend to give me the runaround now. I've noticed that when I try to schedule it they tend to only give me later hours, nothing early unless you walk in the morning and if the alignment bay is open. If anything is modified, they'll give an excuse that they need a master tech to take care of it and that they're only in at certain times etc. I got something else done by them along with the alignment, but they seemed to glance over the alignment even when it was supposed to be done. I didn't get a sheet or anything, but the guy at the front said, "Yea we did it." Got it done somewhere else most recently and I haven't been back since.
#10 ·
Firestone should at least check to see if you need an alignment. I read that it’s a good idea to get an alignment done once a year. If it’s done properly.
Lifetime anything? I’m not so sure, especially with certain Firestone dealerships. Some actually have decent service.
If you do a lot of DIY work on your suspension, it may be a good deal. It will also save your tires from wearing prematurely.
One alignment at Firestone costs around $135. Could be more now in these inflationary times. (Which is a big money maker for all corporations now). Big companies are enjoying this pandemic and supply chain problem.
#11 ·
I've never had an alignment done in 30 years of driving. The only time I should've was when I hit a big pothole in a sports car with low profile tires, my steering wheel was no longer straight. Before I could take it in I hit another pothole on the other side and the steering wheel was straight again. Other than a crash or head first crash into a curb I don't see how a Forested could ever need one. I've never even had uneven wear on my tires.
#14 ·
Vehicle alignment is good to have done periodically to maintain more equal tire wear and can increase MPG as an aligned set of tires can have less rolling resistance. A program offering "TRUE" lifetime alignments is a good value if you plan to keep the car for many years and consider an alignment to be regular maintenance.
An alignment can often be knocked out of whack by lesser impacts than a big pothole or banging a curb; regularly going over speed bumps or drainage "dips" in roadways can also cause alignment issues, as well as bigger bumps in rough road or construction zones, like when a road is getting repaved in sections and you hit the transition between the scraped/shaved section of roadway and the paved sections.
#27 ·
Hi,
Thanks.
I am a believer in the Firestone lifetime alignment. I have them do that and the rotation at the same time (which came with the tires). it's nice to know you can take it in after every oil change (or get your oil changed there if you like overpaying LOL) and get the handling polished up.
#29 ·
Hi,
Thanks.
I had a Firestone lifetime alignment on a car I had years ago. Yes, it was worth it. Despite the bad advice posted by many in this thread, you should do alignments routinely. But make sure your vehicle doesn't require a 4-wheel alignment, which I don't believe is included in the lifetime alignment offer.
#30 ·
It all depends on vehicle. When I had the Subaru SVX, it needed wheel alignments at 20-30K intervals with the Potenza's 980AS. Then it was worth it. My forester XT with the Potenza 980AS didn't need at all.
Hi,
Thanks.
#31 ·
For the first 2 decades of owning cars I never got an alignment unless the car was clearly having a problem I could feel in the handling or some major suspension work was done. Then when I had my first Legacy wagon (yes in the days before the Outback) I trashed a brand new expensive Michelin tire due to alignment issues even though I could not recall any problems with the car drifting etc, the alignment was way off, probably from the zillion potholes on Chicago roads and I could see the steel belts exposed from the uneven wear! Since then I would obsessively rotate my tires and ask for an alignment check with at least every other oil change and certainly any new tire. I rarely ever found any local shop (what was NTB, now Mavis, Sears, Firestone) or dealer said I needed an actual alignment if I had no hint of driving issues. In the last decade+ Ive been using Nokian all weather tires a lot to save having to have true winter ones swapped every season. The directional tread Nokians wear and become noisy like crazy if not perfectly aligned, the tires almost sound as loud as a bad bearing! Now on any car I have directional Nokians, I will get an alignment maybe every 10-20k. Beats buying a new set of Nokians at 150 each! Ive driven some Nokians 60K miles and still had 4mm tread (they have succesive 2mm tread markers) yet with a directional one they are so noisy at 30K if not perfectly aligned I've had to ditch them as the wife was going nuts from the noise. Ive never heard Firestone locally offering lifetime alignments but I've gotten my moneys worth from NTB for 2 or 3 year alignment packages, they also would let you swap to another car once. So I could usually get 2 checks on one car and one sometimes 2 checks on a 2nd car in the 3 years.
Its like insurance, some people need it more than others depending on all sorts of things!!
#32 ·
i bought mine for a little bit less than $199. I forgot how much exactly, $175?? Yea, people don’t need to do alignment that often, but when you do, it’s expensive. So that said, $170-190 for lifetime is worth it for me. You do it 2-3 times depends where you at, you get your money back already. Since I bought it I just do the alignment every time I go there rotate the tires.
#33 ·
Alignment is something that should be done periodically. The big catch with lifetime anything is if the shop is good and if you are going to stay with them for the lifetime you keep the vehicle.
I have found them to be well worth my time in general. It sucked when my shop changed owners they no longer honored the lifetime alignment I purchased as a national chain store.
#34 ·
I purchased it because I do mods and already upgraded the struts and did a spring lift. I already had 2 alignments and still need to have my sub frame lowered to re-center the rear wheels in the wheel well . I also have three sets if wheels. Winter,summer and off road. Lots of tires.lol I have my own TPMS reset tool I use when I do my own wheel swaps.
#38 ·
Hi,
Thanks.
Just be aware, every time you take it in, you'll be pressured to replace allegidly worn struts, balljoints, or any other service they provide.
#39 ·
If you are going to keep the car for a long time and especially if you do your own repairs, I strongly recommend it. Alignments are necessary after any procedure that affects the front suspension, including struts, tie rods, or impacts. It may be possible to change control arms, ball joints, and axles without affecting the alignment but I disconnect the spindles assembly from the struts to make it easier. With the requirement for four identical tires, one tire out alignment wearing out prematurely can result in the need to purchase four tires.
I purchased a Firestone Lifetime alignment and use it at least once a year, after any of the above repairs, just before buying new tires, or before a long trip. One local Firstone shop was borderline incompetent so I go to another one that is quite competent. It's not bad that they inspect the car and recommend other services but since they don't know the maintenance history of the car, they are aggressive in their recommendations. It's easy to say no.
#45 ·
@lxrsub So is it better to get the alignment done just before buying/changing new tires or after installing a new set of tires? I thought to do the latter.
Thanks.
