2015 - Spark plug replacement interval?
4.4K views 8 replies 5 participants last post by  rgarde
From what I’ve read in the manual, the original spark plugs in a 2015 Forester will need to be changed at about 100K miles, is that accurate?
#4 ·
60K miles. They will last longer, however, if you shoot for 60K, there is some leeway if you forget. I recently changed mine with 80K on the plugs. The car was running fine, but the gap was wider than specs. I had the extra plugs in my took chest for a year, and had just spaced it off.
#6 ·
I change mine at 40000 only because I'm afraid of having them seize in the head if I wait until 100000. I've changed mine twice in 80000 miles and it is a pain to do. Each time I replaced them the old plugs looked pretty good. I go a little overboard with preventative maintenance.
#7 ·
I just pulled plugs with 43,000 miles on them from a '15 XT because chemical intake cleaner had just been used and then the valves were walnut blasted. A bunch of other maintenance was being done and so the plugs were replaced. The new plugs were on hand and I was curious how the ones in the engine looked.
The vehicle has 117,000 miles total.
