2015 - Daytime running lights and high beams not working?
9.1K views 5 replies 6 participants last post by  ThorsHammer
I was out the other night and went to use my hi beams, they stayed one for a minute and stopped working. car is a 2015 forester. I have checked all fuses, swapped relays and everything looks good. I have no daytime running lights and no high beams. Low beams work as they should. When I flash the high beams the dash indicator does come on but that is it.
Does this sound like a bad drl resistor?
Please help!
#2 ·
Not sure about the MY15, but I'm thinking the DRL's and the High Beams may be using the same filiment - Not the low beam....
Lower power for DRLs but I think they use the same filament. Have you checked the bulbs to see if they light when jumpered?
#5 ·
As onomarn said "one filament". It runs more or less on half power as DRLs. My OEM bulbs were blackened because the filament didn't get hot enough on DRL to re-deposit Tungsten back to the filament. Still worked but glass had partially melted. I Replaced my DRLs with Philips DRLs and recommend them. OEM resistor system sucks; uses same current for DRLs as high beam and is bad for the bulbs.
GD
