20K views 32 replies 11 participants last post by  mronjan
Hey Guys,
Wondering if anyone has successfully replaced the crappy stock head unit in the 2013 XT Premium? I'm told that it's complicated because of the Harmon/Kardon system that comes in the premium. Apparently, the only way to work around it is to completely bypass the factory amplifier. I'm hoping to put the sony xav-ax1000 in and retain all controls.
It looks like the right harness might not exist although I'm not sure. Any help would be great.
Cheers
Alex
#9 ·
Hey mate, apologies for the delay - I'm rarely on here and didn't see the notification.
I believe I now have everything I need to install the new unit. I'll let you know how its goes and what you need if it works. It hasn't been as straight forward as I would have liked!
#3 ·
Dam 30 days with no one saying anything. dam.
Anyway, yes there are tons of people that swap out the OEM head unit.
Yes there is more adapters and wiring harness needed than the average '90's car. But it is do able.
A simple youtube search can get you the answer you are looking for.
Coming from Australia it will be more expensive, just as everything is for you guys. One online store that is very helpful for DIY stereo installs is Crutchfield.com I"m sure there are many more online stores, hell, even your local car audio shop might have something for you. I would always try local, then online if all else fails.
#4 ·
I've got a 2016 XT with the non sat nav unit.
From a wrecker, I bought a 2016 XT Premium unit with the GPS SD card.
From my limited research, it should be plug and play.
Anyone here done this?
#5 ·
@shotlister It should be. Not 100% sure. The only thing that "might" be an issue is the sat nav antenna. But that should be an easy fix, just grab that antenna from the wrecker. Oh and maybe the under the seat amp, but i don't thing that should be an issue, since it only sends the signal to turn on the amp.
#8 ·
I have a 2011, and replaced the head unit with a Pioneer Apple Carplay unit (one of the NEX units), using an iDatalink adapter to keep steering wheels controls, but also to get gauge information on the head unit too. I have done a couple more installs with my parents vehicles (Toyota sedans, a 2005, and 2018) and they have worked very well. Then I did the same setup in my wife's 2015 Sienna (another Toyota).
#13 ·
@RIPaXe Thanks mate. Wasn't especially cheap if I'm honest due to the custom harnesses which were $245 AUD. The fascia kit was $37 and the head unit you can pick up for about $350 at the moment. Obviously I did all the installation which cut out that cost.
For me, it's an easy expense to justify because it improves the driving experience so much with maps and general usability. Listening to music in the car is also a big deal for me and this improves that experience so much more as well. Since writing the above post I have installed an additional Alpine 5-channel amplifier and 12" Kicker sub. It's sounding verrrry nice!
#27 ·
Hey Mate,
How'd you go with the amp and subwoofer install?
My HK unit has legit just died (does not turn on at all) so i'll be starting the process on replacing and contemplating a hidden sub under the driver seat.
Couple of questions around your amp and sub install:
Did you replace the HK amp with the 5CH amp?
Did you need to run new power / preout cabling, or were you able to use what was going into the HK amp?
I'll post my progress on this thread as I go for fellow AU owners in the same situation.
Cheers dude!
-Alex
#14 ·
Oh awesome that’s actually not as bad as I’d thought! Looking at picking up a second hand forester and just looking at how much I’ll plan to spend on upgrades such as the stereo. You’re right it’s an easily justified purchase haha. Are the original premium head units that bad?
#15 ·
@RIPaXe Yeah the navigation head units in the Premium XTs are awful - just outdated technology that's all. Was probably fine in its time.
Worth mentioning in case you're unsure, if you get a non-premium forester all of the above stuff isn't really relevant. Especially for models 2012 and prior, installation becomes a lot easier and cheaper I really like the premium feel though.
#16 ·
@Alex W Os Yeah man I've been looking at premiums. They just look that bit nicer with the better rims/leather seats/sunroof etc. and if I can change out the stereo for under a grand that's not too bad at all. Been looking at 2011/12 models as the 2013 premiums are just slightly more than what I'm getting back for my hail damaged write off and don't want to go too overboard for the sake of it :(
#17 ·
A Seicane unit from their website or Aliexpress will be substantially cheaper, in my opinion, look better, and offer lots of options including a much larger screen with better resolution. I put one in my 2011 that was being discontinued as an older model for $129 Cdn including shipping
543953
#18 ·
Hey Mate. Yeah definitely looks the part but cheaper ≠ better in my opinion. I've read sketchy things about Seicane so preferred to opt for a trusted brand, especially as sound quality is so important to me. Finding the right harnesses for a Seicane in the XT Premium would also be very difficult considering the Harman/Kardon sound system + factory amp - it isn't a plug and play scenario. It's much more straight forward in the SH Foresters such as yours.
I'd be wary of Seicane, mixed reviews:
543986
543987
I spose if your main criteria is price then it's a winner.
Anyway, my opinion. Cheers. (y)
#19 ·
It was a winner in the price department without a doubt. The fact is, it was priced low enough at an end of the year clearance price that I was willing to try it with the idea of no big loss if it did not work well. That said the unit I received has impressed. It's far superior to the factory-installed 2011 SONY Avic in my Forester in terms of screen size, resolution, boot time, GPS performance, and overall sound quality. It's worked fine in -25 C weather, and in 35 C hot weather, and you can actually see the screen on a sunny day. Not to mention the screen surface which has a touch screen built in that minimizes fingerprints
I would take a lot of the negative reviews with a grain of salt. Here is a more in-depth one for you
For fun what are the anonymous rating sites you posted, and why are their numbers trustworthy?
In my books, SONY made good stuff in the 1980s and has been going downhill since, but that is probably a little harsh. It's just that their quality differential with their competition doesn't seem as great anymore.
I honestly find the unit Alex O installed leaves me underwhelmed. Especially compared to this
Its just sad that its not compatible with a Harmon Kardon system set up. For what RipaXe wants though, I think these are the answer.
#21 ·
It's the web, who knows who and what to trust ultimately - including you and I. haha
All the best my friend, enjoy your Forester. ;)
#28 ·
@whatthe2070 note that @Alex W Os signed onto the forum a month ago. You could send the member a PM - Private Message... now called a "conversation" on this new site. The member is optioned to receive an e-mail notification, so you could receive a reply to your question.
Also...
For the best forum experience, we recommend completing your "Account Details". The optional information you enter there will display when members click "About" in your forum profile. You can also create a custom "Signature" that will display every time you make a forum post. The optional additional information you provide could mean getting forum member replies, or not.
#31 ·
Yup. No problems whatsoever, and has worked fine in -20 C conditions and 30+ hot summer temps. Newer units are probably better still. Its a great upgrade to the car and the size and clarity of the screen are fantastic.Improves the overall look of the dash in my opinion, and if you use another interface such as AGAMA car launcher you can make it look like an OE or better system. If you want to save some money buy one the remaining last gen units without the latest and greatest Android or Processing chip. I paid $129 Cnd which included shipping from a vendor on Aliexpress
Here is an example of someone selling different versions. Here is what I think is the great deal
Otherwise you can also buy directly from the Seicane website but the deals are not quite as good, and you don't get the same buyer protections as on Aliexpress
Personally for these I don't think you really need more than 2GB RAM, but I don't use it to stream movies, or run 10 applications at a time. Boot time is super fast already. If you buy one I doubt you will regret it.
#32 ·
#33 ·
Alex
I also have a Forester XT premium 2013 and am considering a head unit upgrade similar to yours. A question: The Metra 71-1761 harness connects to the powered output (not the pre-amp) from the Sony to the OEM HK amplifier input. This would normally be a no no. How come it works in your case?
Regards
Miron
