2006 - Automatic gear stuck in park? - SOLVED!
94K views 22 replies 13 participants last post by  PleiadianPerson
I have a 06 forester and lately I have been experiencing problems with the
automatic shifter. When I press the brake, normally, I am able to change the gear from park to drive. But lately, it has been sticking as if I was not pressing down on the brake pedal. has anyone experienced this.
is there an easy diy fix? I think I have about 50K miles on it so warranty fix is out.
everytime I need to shift, I have to depress the button next to the gear shift.
your help is greatly appreciated.
D
Discussion starter · #4 ·
@scubadoober and @NAEJ25 thanks for your reply.
when you mean button, do you mean that white slot next to the shifter?
I jam a key in there then shift the gear to get it out of park.
do you guys have pix where I should check?
thanks in advance.
Discussion starter · #6 ·
@scubadoober that's for the info. actually, my wife took the car to the mechanic today before i saw your email....it would have been exciting to find out the prob using your instructions...thank you anyway.
it cost $82 to get it fixed.
one thing i noticed was that the back brake lights were not working....
