2003 - Front, upstream O2 sensor removal? - Solved
2.7K views 5 replies 3 participants last post by  Inspector
Vehicle Details:
2003 xs
Anyone have any tips, tricks or ways they got the 1st catalytic converter’s downstream o2 sensor out? It being pointed upwards makes it hard to get from the top and bottom of the car…
#3 ·
I'm struggling with this right now actually on my 2010x. That little SOB is frozen in there pretty good. I can get to it with a 20" long 3/4" extension coupled with an angle joint to either a crowfoot or socket O2 adapter, but it doesn't seem to matter. Even hitting this with an impact or breaker bar doesn't seem to be working. Even heating up the manifold first does nothing. I'm thinking i may need to drop the manifold to get a direct impact on the bugger.
#6 ·
Finally got it. Trick was to pull the passnger wheel, remove the one clip on the splash shield in the wheel well, and get at the thing with a (crowfoot O2 sensor socket)-(impact swivel joint)-(6in impact extension). Got the impact more directly on it. Oh yea, and I also made use of my new Dewalt DCF961 which was probably overkill for this, but is a freaking beast.
