2000 - Popping noise, while driving, engine shut off, now won't start?
9.8K views 17 replies 5 participants last post by  Hash1985
Help. I am not a Subaru owner but my daughter is, so that makes me the owner of Father Figure Automotive. She has a 2000 forester that while driving made a popping noise (her words) and suddenly started decelerating. It ended up shutting off and won't restart. It cranks but doesn't sound like it is getting fuel or spark. I have done the following - verified timing, verified spark, replaced cam and crank sensor, verified fuel pump relay working, verified fuel pump working, verified fuel pressure regulator working, checked all fuses and fuse-able links, verified fuel is evident at the filter out port. Also the car did not throw any codes.
I would like to repair it myself but I am stumped, don't want to take it to dealer for troubleshooting/repair as the costs would be more than the car value.
Discussion starter · #6 ·
To confirm, was this the cam timing that you verified?
Has the cam belt, water pump etc. been maintained as per maintenance schedule?
Is the vehicle AT or manual?
2.0L turbo? Or N.A?
Do any of the cylinders fire at all when cranked?
After attempting to start, can you smell fuel coming through to the exhaust? And are all the plugs wet?
Can she describe how she was driving at the time? Uphill, downhill, flat, cruise, accelerating, which gear, what speed etc
Can she describe how the car reacted other than the sound? Did the power just switch off like a light? Did it jerk back and forth whilst it was popping, did it kick hard or violently?
Was the popping very loud? Did it come from the front or the rear of the car? Was it an occasional or intermittent pop? Or was it consistent or rhythmic sound? Was the popping rapid, or slow? Did the popping start from the instant the power died, and continue the whole time till the car stopped? And was the volume and/or speed of the popping sound, consistent with the deceleration of the car and/or engine?
Yes, I confirmed that the cam timing was correct in relation to the crank, timing belt and associated items were replaced less than 50k ago
vehicle is manual, not turbo
no cylinders fire or sound like attempt to fire
flat ground, accelerated to 70 mph, highway
power stayed on untill she pulled over and turned off the car, then wouldn't re-start, no jerking or any other unusual vibrations felt.
pop wasn't super loud and appeared to come from front of car, only one pop heard,
Discussion starter · #7 ·
oh...boy.. that does not sound good at all.
well, you check spark, fuel, all you need to do is check for compression.
Did you check for metal shavings in the oil? or milky coolant? Could be a blown head gasket.
If I where to guess, spun rod maybe a bad valve as collateral damage. But that's just a guess.
Let us know after you do a compression check. You can buy the tool or rent it at most auto parts stores.
i did check the oi, and there is no apparent metal in it, the coolant is normal. I did not check the compression with a gauge as there is was no loss of any type of fluid, and when turning the engine over by hand you can feel the crank going thru the stages, ( i know you can't always feel all the cylinders, but if any cylinders had compression then you would still have some attempt to start)
Discussion starter · #8 ·
2.0L turbo? Or N.A?
also, there is no evidence of fuel at the exhaust, smell or liquid. i did not pull the spark plugs and check for fuel at the cylinders yet, that will be my nest step.
Discussion starter · #9 ·
Also, as i replied to DOGS, the engine was still running and did not shut off on its own. My daughter pulled over after the pop and deceleration and then shut off the car and it wouldn't restart
Discussion starter · #11 ·
Have you checked all Earth straps?
Does this model use a cable actuated throttle and choke? Maybe check proper connection and routing; and adjustment.
I haven't checked all the grounds yet.
I pulled the injectors and rails today, after cranking the car there was no fuel evident on the engine side of the injectors, I removed the injectors from the rail housing and the rail was full of fuel. As the engine will not attempt to start i can only assume that there is an electrical issue with the injector harness as it is occurring on all 4 cylinders.
