so, there i was watching a youtube vid on how to accomplish the replacement of the hub assembly of a subaru, and once the guy took those last four bolts out that hold the piece in place, it gently falls out into his hand...i'm now thinking he must be in southern cal, because once i took off the last 4 bolts, my midwest-winter flavored hub assembly seems to be welded in place with the expected corrosion. it's only being held in place by a 1/4" lip that inserts into the 'hole'. i've used Blaster PB along with a few good whacks of a 8lb sledge, but it's a no-go so far. i tried an air hammer and that moved some stuff around, but it's still stuck in place. the easy part was using that air hammer to push that yolk back, but it's still hard. i gave it a good dousing of PB and will let it sit overnight and give it a few more sledge hammer whacks in the morning.
does anyone have any tips on getting this piece off? heat? more whacking? maybe coming from behind with an air hammer? i can move the yolk out of the way just enough to do it.
anyway, it's a good workout, saving me hundred$ and thanks in advanced for any tips!
berbes
berbes
