09-2017 - anyone have rear suspension torque specs?
23K views 2 replies 2 participants last post by  rule292
Evening Ladies and Gentlemen,
Does anyone have a service manual and if so would you be so kind as to look up the torque specs for the rear suspension components that bolt on to the knuckle? I had to pull mine to replace a rusted in bearing so now I need to re-torque:
Leading suspension link to knuckle bolt
Trailing link to knuckle bolt.
Front locating link ball joint nut
upper rear a-arm bolt
Caliper bolts
And the center nut.
Thank YOU in advance!
