Has anyone removed the pcv fitting on a 2006 sohc block before? Pic to show what I’m speaking of. Apparently my brain is on malfunction cuz to me it looks like it should thread out however the outlet off of it looks like it may cause interference. I’m in the process of a Frankenstein rebuild and need that to go on another block. Or if anyone has some clever ideas on what I can use as a replacement would be phenomenal!!! Thank you in advance. I’ll post the swap soon.
