Using the valet key on keyless entry vehicle
1 reading
28K views 12 replies 6 participants last post by  jzmtl
Hello everyone,
I recently bought a 2015 Subaru Forester 2.0 XT Touring. It has keyless entry and is push-button start and therefore has a key fob that doesn't need to leave my pocket. Also, the forester is smart enough to now allow me to lock the key fob in the car because it senses the key inside the vehicle and will auto-unlock the doors. I love this feature for many reasons and I love the vehicle so far but I have a strange problem.
I am an avid surfer and when I drive to the beach I need to lock my car and cannot take the electronic key fob with me in the water for obvious reasons. I tried leaving the key on the tire or under the bumper of the car but that leaves the key in close proximity of the car to enable the keyless entry (if anyone walked up and pressed the trunk release button, it would open). I figured out that if you wrap the key fob in aluminum foil and leave it inside, it will hide the key from the car and allow me to lock the car from the inside and as long as I have the valet key portion of the key fob, I can at least unlock the driver side door when I get back from my session. However, every time I do this, the alarm goes off and I need to quickly grab the key fob to stop it.
1) Does anyone know how to lock the car/unlock the car with the valet key without the alarm going off?
2) Is there a special water-safe key I can get made to lock/unlock the car and not worry about this happening?
3) Any other magic solutions for this problem?
I used to have a VW with the same technology and the special surf key/valet key that came with it would allow me to lock/unlock the doors without the alarm going off and let me lock the key fob in the car.
Thanks,
Ausaus
#2 ·
When you say "valet portion of the key fob," I don't know just what you mean. Our 2015 Premium is pretty basic and the key, with all the buttons on the key head, is needed to start the engine, so yours may be entirely different. Anyway, we have a separate valet key with no buttons on it, and it unlocks the driver's door without triggering the alarm. It would be nice for you if there is such a key in with all the material that came from the dealer and you've missed it. Hope so.
#7 ·
Hope I don't double post here. What I had written disappeared when I tried to make a correction. Anyway, I feared your key system would be completely different, but I hoped there might have been a separate key that had been overlooked.
It didn't occur to me to try our valet key until sometime last week. When we had the windshield replaced in our 2009, we had to leave the car on a lot for several hours until the shop was ready. That was the only time the feature was any more than an irritant for us. I simply cannot imagine a value for having the key set off the alarm in any circumstance.
#4 ·
AFAIK there is no option that allows entry with the "manual key" without the alarm going off.
#8 · (Edited)
With my memory bumped by jjlwis's post I reread the Owner Manual... and there is solution, although it doesn't exactly address they OP's question about using the "valet" key. Using that key will always trigger the alarm. The below method omits its need altogether, and provides a way to gain keyless/remote-less entry without the alarm going off. Keeping the key on hand, just in case, is a good idea but it's not necessary with the referenced entry method.
On pages 2-19 through 2-21 the OM outlines the PIN Code feature, which allows entry without the key or remote. There appears no mention of such entry triggering the alarm, thus PIN Code entry should solve the OP's problem.
#5 ·
A while back, subaru had a feature on the forester /outback.. That in the rear tailgate there's a button, that allows you to hide the smart key inside the vehicle.. But it's a complicated process of button presses in sequence in order for the car to not "see" the key.. You can probably find a tutorial on YouTube. Good luck.
Sent from my XT1254 using Tapatalk
#6 · (Edited)
If you wrap the fob in foil and put it into a hide a key you should be able to avoid the vehicle sensing the key. Then hide the box with key inside. Only problem might be someone watching you hide the key.
Another option is a key safe that uses a trailer hitch receiver. Also wrap the fob, lock in the safe, and most use a combination lock, no key.
EJ
Sent from my iPad using Tapatalk
#9 ·
FWIW, after writing this morning I decided to try again to make sure. The car was unlocked, so I locked and unlocked it with the ignition key. Nothing happened. After several attempts with no alarm, I locked the car and waited several minutes. This time the alarm sounded as soon as I opened the door. Since I did my tests last week all within fractions of a minute of each other, it begins to look as if Fate is right.
#12 ·
This is getting complicated. :)
The setting in the MFD is for the chirp indicating lock/unlock... not arm/disarm of the alarm.
HOWEVER... pages 2.25 through 2-31 in the OM outline procedures for both disarming the alarm and rearming it. There are other changes to the system a dealer can make.
Choices. The OP has em.
Personally, I'm not going to disarm my alarm... which is why I read, then put from active memory, that section of the OM. PIN Code is my choice, but that's just me. The OP has options to end his frustration, one way or another.
#11 ·
Just to be clear about what's being called the "valet" key...
The current keyless remote isn't like earlier systems, where there was a separate valet key to operate the vehicle that one gave to the valet instead of the remote-buttoned one, or the ignition key on non-remote systems. The ignition key (with/without remote) could lock/unlock everything, but the valet key did everything except lock/unlock the glovebox.
With the current remote for keyless systems, with the little mechanical key contained inside it... that separated key can operate the keyed locks (door and glovebox) so that the glovebox can be locked with it and then kept on one's person, and the remote is given to the valet so the car can be operated, but with personal/valuables unavailable to the valet.
The distinction is mostly semantic. The idea is the same, but the component exchange with the valet has changed... they no longer get the key.
