841 - 860 of 1,376 Posts
I have 17x9 et42 using 245/45/17. The front tire goes the line of the car. The rear tire can benefit from a lower offset, I'm thinking 35 would be perfect. So the ideal setup would be 17x9 et42 for the fronts and 17x9 et35 for the rears.
17x8.5 +43 offset on a 2000 Forester with WRX pink springs. Will they fit with any tire size without rubbing?
Debating between a used set of Advan RGs or JDM V7 (both gold).
Will the V7 fit with 225/45/17?
Thanks all!
I've searched and searched for the answer to my question. I realize it's probably right under my nose...However, I'm looking to fit up some 17x8 ET35 wheels on my 225/55-17 tires. I have an '09 Forester. I'm also running '08 STI take-offs.
Any thoughts about how the fitment will be? Or if I'll run into any issues?
Thanks in advance,
Craig
2014 BRZ wheels with 225/55/17 on a 2004 XT with 07 STi struts (with 2004 STi tophats) and JDM pink springs. Tires juuust barely clear the bottom of the rear spring cup on the strut. Looks awesome though.
question:
I just traded in my jeep wrangler and had som stock take offs laying around.
The tire size is 225/75/16.
Will they fit on my stock 2010 forester alloy wheels. The size on there now is 215/65/16.
Thanks,
Dan
I am looking at fitting some STI wheels with 5x114.3 fitment to my 2004 xt. Wheels are 17x8 et53
I just need to know the best thickness adapters to go with
I think 20mm at the front, making the wheels a offset of +33 on a 8j rim
Would the experts recommend spacing more at the rear to get a level look?
I think I will need arch work which is fine. Just don't want my wheels to be in the arch at the rear and flush at the front!
Does any one know, and have pictures of the best front and rear offsets on a 2004 xt?
Any help would be great, ta James
Are all 06-08' Subaru Forester models equipped with a 56.1mm diameter hub? Any other Subaru Models with 5x100BC 12mm studs and 56.1mm hub?
I'd really like to find used 16" wheels for my XT that are hubcentric.
Thanks in advance!
So I've looked all through this thread and can't find what I'm looking for.
I currently have an 05 XT with 2007 WRX take offs and would like to fit XXR 18x8.75 +35 with 225/40/18.
If anyone is running anything similar and can tell me what issues they might be having with rubbing it would be greatly appreciated.
2006 WRX wheels with 225/50/R17? They should fit just fine, but will they look good? Should I go with 55s? 235/50? What's the best size to go with that will fit on a 7" wide rim? I like how 245/45s look, tire rack says that 245s will fit on 7" rim..
Sent from my Nexus 4
Hey guys, I'd like to put some rims on my '12. I was looking at the Work Emotion CR's and their look a likes (Rota Torques, etc.) in Hyperblack. If I wanted to do 18's (not sure what best width would be) what size tire and offset do I need to run ? I'm personally not a fan of the super stretched or poke look, but a very small stretch is ok and when done right looks good to me. I'd like an aggressive setup though. My forester is on either wrx or sti suspension. Haven't gotten a chance to look up part numbers. I'd really like to run 19s but not sure they'd fit as low as the vehicle is without really low profile tires which in NY will suck lol.
I want to get a set of 18" XXR 531 for my currently stock 11' XT. I am considering gold 18x8.5" +35. Would that give me a decent flush look without rolling the fenders? I might also be adding wrx struts and springs at the same time.
Anyone have a recommendation of rim width/offset and tire size for 18s on a SH with wrx/sti suspension ? Thinking I want to be around a 245 tire. Also do the work/torques clear brembos ? Don't have them now but definitely see them in my future. Thanks.
After an email to wheel dude I found out to get the concave version of the torques I have to get 18x9.5 with a +35. Whats size tire can I get away with on a sti suspension ? Id like to run at least a 245....I was thinking potenza RE-11's in 245-40-18. Would this fit without rubbing and without rolling the fenders ? Right now I have none but was thinking of doing some 1/2" saggy butt spacers. Please advise...
does anyone know if 18x9.5 enkei raijin offset 45 with 255/50 or 245/50 tire will fit 2014 SJ Forester with rolled fenders? cuz im planning to get some coilovers and gtspec lateral link with the wheels?
I made my own thread about this because somehow I missed this one lol... but my question is:
Alright, well I think I've found the rims I want, but I now need help figuring out what offset will work with my suspension.
I have an SF sitting on JDM V7 struts & Swift springs. I have no probelm rolling my fenders but I do not want the wheels/tires to rub on my struts as I don't know if I will ever want coilovers or not.
The wheels I want are Wedssport SA 70
I want an 18x8 wheel... what offset will I need?
I've found a set I could pick up that are +50.
Can these work with a wheel spacer & rolled fenders?
What size of tire would need to work with these?
