2016 - Limited - ODS module electrical schematic?
86 views 3 replies 3 participants last post by  carloliveira
Vehicle Details:
2016 Forester Limited
Can someone please provide electrical schematic WI-307 for 2016 Subaru Forester Limited which is referenced in the ODS diagnostic manual, I have to pin-out the ground and power for the module before I dive in to buying a new lower seat for the passenger side, all connections are visually good up to the ODS pressure sensor mat, I have removed the passenger seat and dis-assembled it for inspection, the mat may be bad but I want to check the ground for the harness that powers the module. I have tried to test the ODS pressure sensor mat with a Fluke Multimeter in both resistance and capacitance setting but nothing jumps out at me that says its definitively bad. Capacitance varies slightly when I measure at the ODS harness that plugs into the module but its not telling me much.
#2 ·
Occupant Detection - Airbag disable? It took me a bit to even figure out what you were looking for.
Reactions: 2.5x_sleeper
#4 ·
@sgoti Thanks Glen thats what I needed to pinout test the module but I didnt want to touch the CAN pins because I do not want to trigger anything with the AIRBAG system. I have verified input voltage and clean ground at the ODS module so looks like it all falls on the ODS Sensor built into the lower passenger seat at this point.
