Hi Everyone,
I need some help in wiring my Bi-LED projector fog lights' "high beam".
What I intend to do is to run a separate line and I don't want to just tap and splice the OEM wires (or atleast minimize it). I will be using a foglight wiring harness with a 4-pin relay.
My plan is that the high beam would only turn on when the main (low beam) foglights are on.
I got this rear fog light switch from a junk yard. Thing is, I am not familiar with the wiring or where should each wire go.
Hope you can help me out on this. Please advise which wire goes to where. And again, this should work ONLY when the main foglight switch is ON.
TIA!
TIA!
