As far as the HVAC:
If my understanding that it controls flow to the heater core is correct, it is just a complicated ECU controlled thermal valve for cabin heat.
Heater core valves are not a new idea, just an abandoned one in the ~1980's.
They used to have a cable or vacuum controlled valve to control flow to the heater core. Then cost cutting eliminated it, and the heater core became part of the thermostat bypass circuit. It is always hot inside the HVAC module as long as the engine is making heat.
The heater core was/is isolated via air blend doors. Depending on the design, it was either so so, or pretty darn effective.
I can only speculate that Subaru went back to the older design so they could use a smaller ac compressor and steel maintain cooling efficiency in the cabin.
Whether or not it worked is another topic.
If the AC compressor takes less power to run, it does impact emissions by burning less fuel.
I know this is straying from the original topic, but I'm not sure where to post it.
It involves emissions, engine control, HVAC, engine cooling and the TCV.
So I figured I would just leave it here.
If admin. can figure out a better place to split it to, that's fine with me.
