Curious if anyone with an 2014+ SJ forester has had wheel bearings replaced?
My 14FXT is about to hit 65000 miles and I'm hearing a hum, not too loud but it's there ... I'm assuming it's coming from the left driver rear wheel but not 100% certain which wheel.. or if it's even the wheel. It almost sounds like I have offroad tires with thick tread on driving at 30-40mph, goes away from 40-65mph but around 65+ it comes back. Only found this out when my Pandora music went out in a dead spot driving through some country roads and such.
UPDATE: Problem Solved, see: UPDATE: PROBLEM SOLVED! REAR WHEEL BEARINGS REPLACED (post #21)
UPDATE#2: July 2017. I'm pretty sure my rear wheel bearings are going out again after approx 30k miles. Im at 94k miles now. I'm hearing the same droning and noises at certain speeds as before around 55-60mph...and eventually will get worse. Did a search of Timken hub assemblies/bearings and apparently they aren't as great as they seem. Fml. Gotta order and install a new set now. Probably go with MOOG or OEM. Update: Ordered MOOG from Advanced Auto Parts with a 3 yr warranty.
UPDATE #3 : August 2017. TIMKEN Bearings definitely getting worse. Received and replaced with new MOOG bearing hub assemblies on both rear wheels. Found the TIMKEN bearings I put in last year with less than 30k miles on them have already began failing on the passenger rear...it was rough and slightly grinding when spun by hand after removal. TIMKEN sucks, don't buy!.. apparently their quality has come down as I've read too late and now experienced. The TIMKEN driver side rear was okay but I didn't trust them so I replaced them also. The silence is back. Total cost of repair $267 for both rear bearings and doing it myself in 2.5 hrs. Got a decent discount from Advanced Auto Parts and apparently a 3yr warranty. Only time will tell how these MOOG bearings will do. IF I keep my car that long. Not going to lie, 3 sets of rear wheel bearings with less than 100k miles is horrible. Front bearings still original and ok - cross my fingers.
UPDATE #4: May 2020. My car is holding up great at close to 160k miles now. It has been a joy owning this car! I still love it every time I walk up to it. Anyway, the MOOG wheel bearings have held up for over 65k miles. No complaints, I hope they last me up to 200k at least.
