2012 - DIY ► Clutch Service Guide - write up!
18K views 9 replies 7 participants last post by  WAwagon
Great write-up @Sleezer1533 - I will add a link in the DIY section; just one comment that the ground/earth/negative should always be removed first / replaced last to prevent any sparking. For this job probably best to remove both - & + cables
Disconnect your positive battery cable
