Nozzle on passenger side windshield washer has stopped working. How do I replace it?
Jack, thank you for this tutorial. I also could not find any how-to instructions to replace the windshield wiper fluid nozzle for my 2014 Subaru Crosstrek, apart from this post. Your write-up was perfect. The correct part number for replacing the passenger side nozzle was 86636FJ030 in my case, but other than the basic installation procedure was the same and should work for most Subarus from 2009 to 2014. Likely others too. I did not plan ahead to replace the cap clip things and just used zip ties for now. Seems to be secure.I had to fix mine before a pre-Xmas road trip and found this and another thread on the site but not much descriptive info on "how to" so I took one for the team and have photos. This can be done yourself but there is some disassembly needed. If you have all the parts and tools together you can get the job done in about an hour...here is the nozzle you'll need:
