I seem to have an issue with the AC belt coming off a couple times. Thought I'd double check here on the forum before I try it yet again or start replacing things.
Both times the belt came off towards the engine - wedging itself behind the crank pulley. Its worn or broke a hole through the timing cover right behind the crank pulley from where the belt hit it or burnt through it. Going to have to pull the crank pulley and see if I can patch it with something, or perhaps have to replace the whole timing cover.
The second time the belt came off it took the alternator/PS belt too.
The tensioner is corroded very bad, but I did get it freed up enough to adjust to seemingly good tension. The idler might have a small amount of play, not sure if that could be it, or perhaps something to do with the AC compressor? The AC was working ok until the point the belt came off. I'm a little puzzled on this one, I figure I may try to source a new tensioner bracket and idler if I can find one reasonable unless someone else has any ideas.
