2009 - Checking A/C refrigerant pressure without recharging?
1 reading
174 views 13 replies 5 participants last post by  2badknees
Forester 2009
Hi All
Forester 2009, AC system never been serviced, still was blowing some cool air 15 year later.
The AC system has been recharged at service shop.
It's blowing cold arctic air however two things 1) the engine revs dip low when idling and AC kicks in 2) observed AC clutch engages and disengages quite frequently, like every 10 seconds or so
I must say I never looked at the AC clutch before but it doesn't look like this is normal?
I would like to check AC low pressure ( and by doing this to make a judgement on the correct quantity of refrigerant in the system). I've been googling for hours and discovered and listened for tens of videos now, that explain how to recharge AC system, however I couldn't find a single one that explains how to check the pressure and that's it.
I am hesitant to connect manifold gauge to LP/HP port, because I don't have vacuum pump and concerned that I would let air into the system. And then, the hoses that come with the gauge are quite long, they would grab a fair bit of refrigerant I imagine... and then I found a simple $8 tool that have just one short LP hose and the gauge... can I just connect that thing to LP and check pressure? Should engine be running when I connect? or should I connect first and then start the engine?...
It's seemingly simple operation, but as I have never done it before there too many questions that introduce uncertainty and I am reluctant to stuff it up...
Appreciate any pointer!! Thanks
#2 ·
With a gauge set and compatible small can of refrigerant, it can be done.
Assuming the system hasn't been sucking air, the system will have static pressure when it's not running. This pressure will be more than atmospheric pressure.
#4 ·
Thanks for your reply.
I don't have a refrigerant can, these are not allowed for sale to general public in Australia. I just have a tool, which is a piece a hose with LP connector on one end, can connector on another end, and pressure gauge in the middle.
#3 ·
If the system has any refrigerant in it it will have pressure. Since the clutch is engaging, that to me indicates it does have some. Connecting a set of manifold gauges to the LP and HP lines will only lose a very small amount of refrigerant. You'd only need a vacuum pump if the system was completely void and you needed to pull it down before recharging.
#5 ·
The system is full of refrigerant, it just been recharged. No leaks.
It appears overcharged to me hence I wanted to check the pressure on low side. Not sure how to do it safely... should the car be running and ac running or not... would the system suck air from the manifold gauge or not... should the gauge be connected before the AC started... it's really 30 seconds procedure I am after, but the only videos I can find is how to recharge the system. I need just to check the pressure. Nothing else.
Cheers
Leakage almost always occurrs at the HP/LP valves. Everyone should take a minute amount of silicon grease or vasaline and put it where the oring on the cap seats
